I have a 2005 Yukon 5.3 gas. It just up and died on me one day throwing a code referencing the crank position sensor. Replaced that. Also changed out the cam position sensor. Same problem... It runs for awhile, then stumbles and dies.
A buddy of mine disconnected my MAF when the stumbling was happening, and the vehicle now runs just fine... I swapped out the MAF to a new one, and when connected the engine does the same thing. It'll run fine for a few minutes, then it will stumble and die.. It no longer complains about the cam or crank sensors.
No idea.. Not sure if it's temperature related, or other weirdness. I let it run for 30 minutes and drove it around the driveway with the MAF disconnected last night and it ran fine.
It now throws a check engine light code refrencing the MAF, but otherwise seems to run just fine.
Apr 10, 2016 at 3:52 AM
