Engine sputters and bogs during acceleration
150,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MAX KEITHDAVID GARRETT
Idle is good, but when i accelerate, especially going up hills , the engine coughs and sputters and won't even go the speed limit. i changed the spark plugs, oil, fuel filter, air filter, and used fuel injector cleaner. idle is perfect; acceleration still bad.
Jun 12, 2019 at 5:41 AM
Hi Max,
Sounds like this is a weak fuel pump. Let's start with getting fuel pressure readings when the vehicle is acting up.
Once you get the fuel pressure, I suspect we will find it is not the proper PSI.
Please let me know what you find. Just in case, I included the procedure on how to replace the pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Jun 12, 2019 at 6:54 AM
