Engine sputtering at startup, code P301
2008 DODGE CARAVAN
200,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
XTREME47
Cold or hot , 90% of the time when I start the engine, it is sputtering , as if one or two spark plugs do not work. But after around thirty seconds all is okay, power okay, driving okay, no power loss. The misfire code P301 comes up, a mechanic suggested to change all the spark plugs with something of good quality, even though I changed them all few months ago (from Canadian tire). Other than bad idle at startup , all is okay. When the startup is bad , I feel in the cabin bad emissions , they go away when the engine comes to normal, after about thirty seconds from engine running.
Jan 27, 2019 at 12:46 PM
Good morning,
This sounds like you may have carbon build up on the intake valves and when this happens, the carbon absorbs the fuel until it gets hot. After it heats up, it will pass it and the cylinder gets fuel to burn.
You could or need to have an upper engine clean done with something like GM top engine cleaner.
Also, does it smoke while this is happening?
If a fluid other than fuel leaks into the cylinder overnight, it may be burning off.
Jan 27, 2019 at 7:16 PM
XTREME47
Good to think about it, however it is doing this even if I stop and then re start the engine after five minutes after being normal hot. When this happens, there is no smoke coming out of the exhaust, only in the cabin I smell heavy emissions , no smoke , so it seems like there is venting emissions around the engine that go into the cabin during the sputtering .
Jan 30, 2019 at 11:54 AM
You need to start somewhere. Do the basics such as a tune up.
Jan 30, 2019 at 1:21 PM
XTREME47
Got it, thanks Roy !
Jan 31, 2019 at 3:59 PM
You are welcome.
always glad to help.
Jan 31, 2019 at 5:58 PM
