Engine sputtering and struggling to accelerate, feels like it's backfiring?
105,000 MILES • 1.6L • TURBO • 4WD • AUTOMATIC
HGWK
  • 50 POSTS
Engine sputtering and struggling to accelerate, engine would increase in rpm's but if feels like it's backfiring. It does not trigger any engine codes. I've replaced the spark plugs, checked the coils by purchasing a new coil and trying it on each of the cylinders without making any difference. I've cleaned the valves on the intake side. I have soaked them for several days in engine and part cleaner as I cycled the engine, it seems that it took a lot off carbon buildup but the problem still persists. I found no evidence of coolant leaks inside of the cylinders, neither on the spark plugs or the coolant level. I've used some fuel injector cleaner and drove it for about 60-70 miles without an effect. I've also used Seafoam GDI valve cleaner. Im suspecting either a bad injector(s) or carbon buildup on exhaust valves or burned valves or maybe a clogged exhaust system. Please let me know if you have any ideas or suggestions or similar experiences with these or what I can do next? Thanks
Sep 25, 2026 at 1:33 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Start with recorded scan data during the symptom: misfire information, fuel trims, commanded versus actual fuel pressure and relevant air-pressure readings. Have the technician use Ford specifications for this engine; the pressure figures in the replies have not been verified. Complete the planned compression test and investigate an abnormal cylinder with a leak-down test. Inspect the intake and boost plumbing disturbed during earlier work. Test exhaust restriction if the findings point that way. Do not add more intake solvent or open direct-injection fuel lines to look for fuel. The useful next step is a measured comparison between fuel delivery, cylinder condition and airflow. That can identify which system needs repair before another part is purchased.
Guidance references and applicability
HELLA: High-pressure fuel-pump diagnosis https://www.hella.com/techworld/en/technical/sensors-and-actuators/checking-a-high-pressure-fuel-pump/ General support for comparing diagnostic data and checking the supply side before condemning the high-pressure pump. Use the actual vehicle's fuel-system procedure and specifications. HELLA: Ignition-coil diagnosis https://www.hella.com/techworld/uk/technical/car-electronics-and-electrics/check-ignition-coil/ General support for checking ignition wiring, control signals and mechanical contributors to misfire. Its example vehicle and measurements are not specifications for this question.
Read the replies · Discussion summary and reported outcome
MECHTRIX
  • 599 POSTS
The vary best and fastest way to find out whats going on is you need to scan it to see if any diagnostic codes have been cast that would be a great starting place since there seems to be alot going on kind of all at once ..that said If you dont have a scan tool you can take it by most of the chain autoparts stores and they'll most likely scan it for you fir free ..write down the codes if any are found and please post them here so we can get a few more ideas about whats going on if that sounds good we'll see you back here soon ok ? We're glad to help Good luck .
Sep 25, 2026 at 11:08 PM
MECHTRIX
  • 599 POSTS
I noticed you said there are no codes right now thats strange my guess is that you will have some soon unless theres a can bus non comunication issue..also what type of scantool was used if you dont mind me asking ? Thanks again.
Sep 25, 2026 at 11:14 PM
MECHTRIX
  • 599 POSTS
Also did you check or test these things
Like all the usual suspects plugs fuel delivery charging sytem any broken cracked disconnected hoses ?leakdown test compression test ?
Thanks and good luck
Sep 25, 2026 at 11:23 PM
HGWK
  • 50 POSTS
I have not done the compression test yet. The plugs are new as I mentioned. What should I test in regards to fuel delivery? Should I test for the fuel rail pressure and if so what is the normal psi range for this model? I'm using bidirectional scanner and it would trigger codes when I was playing with coil and injector connectors so the system is working. I know that this is the worst year for these escapes with 1.6 engines and that they have a lot of issue with them. I'll perform the compression test end report back for now and I'll do the leak down last since i don't have the test kit and I'll need to see if I can rent one. Thanks
Sep 26, 2026 at 7:23 AM
MECHTRIX
  • 599 POSTS
..so On this car it has direct injection wich requires high and low pressure lines and 2 pumps 1 lower pressure pump is in the tank and 1 super high pressure pump engine driven bolted to the engine in order to operate correctly .. the intank pump that supplies the so called low line with the pressure of
55 to 80 psi key on but not running
.. then can be tested running is 70 to 90 psi at idle..
Then theres the line with another higher pressure pump to make the magic happen the standard pressure for that is
250 to 400 psi at idle only ..
Then much higher under load but note" these can be measured at idle..only (vary high pressure) so dont increase rpms or load the engine during this test only test at idle ...wear protective gear and use high caution these high pressures are dangerous make sure your guage is capable before you test it ..good luck
Sep 27, 2026 at 6:21 PM
MECHTRIX
  • 599 POSTS
Check all grounds and power suply cables make sure theres nothing that can spark while working with gas use extsream caution do it outside ...these pressures are extreamly high and have a funtioning fire extinguisher handy if you have any apprehension abort the test good luck .
Sep 27, 2026 at 6:28 PM
Discussion summary
The owner of a 2013 Ford Escape 1.6L turbo reported sputtering, poor acceleration and a backfire-like sensation without fault codes. New plugs, trying a replacement coil at each cylinder and several cleaning treatments did not resolve it. Compression testing was planned. Replies discussed fuel delivery and mechanical checks.
Reported outcome: No compression results, confirmed fault or successful repair were reported.
The discussion does not establish a failed injector, burned valve or restricted exhaust. The cleaning methods and fuel-pressure specifications in the replies are not adopted as verified procedures.
Read the original discussion
