Engine specs
152,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
BRANDO PULEY
  • 8 POSTS
I need the torque specs on the camshaft gear bolts and the valve timing marks on the car listed above with a 16/1.8 L engine.
Nov 17, 2017 at 4:50 PM
STEVE W.
  • 15,404 POSTS
Timing marks rely on the tool used to hold the sprockets as they are not set inline but offset by a small amount. Marks 3 and 4 are the timing marks with the engine at #1 TDC.
Torque for both actuator bolts is 37 lb ft + 150°+ 15°
Nov 17, 2017 at 11:33 PM
