Engine Sounds
1990 ACURA INTEGRA
160,000 MILES • 4 CYL • AUTOMATIC
SSMITH4562
The car was just running 3 days ago but the engine was knocking and now it won't even start. Could you please guide as to what is going on and how to get it checked and fixed pleased.
Apr 21, 2016 at 3:01 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge autoparts rent it.
https://www.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator if engine will not turn over then see if it's locked up and will turn by hand.
Apr 21, 2016 at 5:40 AM
  • 55,394 POSTS
Ssmith4562
Can also remove the spark plugs and see if the engine cranks over? you might have a blown head gasket
Apr 21, 2016 at 10:05 AM
