engine sound after repairing the steering pump?
75,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
PORTGAS D ACE
  • 28 POSTS
hello,
After i repaired the steering pump the engine sound became so loud. What's the problem? Note: the steering is working good now.
Jan 27, 2024 at 4:56 AM
  • 110,248 POSTS
That is a good question. Does the sound seem to come from the engine itself or one of the belt-driven accessories? Are you certain the belt is properly installed? Also, how would you best describe the noise?
If possible, record and upload it for me to hear. Also, pay attention if it seems louder at different points. For example, is it louder at the top of the engine, the bottom, or either of the sides?
As a test, you may want to remove the accessory drive belt and start the engine (only for a few seconds) to see if the sound is gone. If it is, recheck all belt-driven accessories and make sure the belt is routed properly.
Jan 27, 2024 at 1:05 PM
