Engine sludge problem
74,500 MILES • 2WD • AUTOMATIC
NAMAL
I recently purchased this car second hand it is the LX model. When I scanned the vehicle for troubleshoots, they informed me that the engine has developed the sludge problem. Further they advised to clean the engine mechanically by dismantling the engine or by a chemical flush. What should I choose? Is chemical flushing is bad for the engine?
Jan 23, 2017 at 8:41 PM
STEVE W.
  • 15,405 POSTS
Chemical flushing is not "bad" but in many cases it will not remove all of the crud and sludge. So you end up with areas where you still have sludge but now that sludge may be "loose" because the chemicals softened it. That could break free and plug a bearing oil feed or block oil flow to a camshaft.
Tearing it down takes more time and money but you can also check the parts, replace things like the timing belt or chain, water pump and gaskets. When it goes back together those parts that are "service items" are now done and you know the inside of the engine is clean.
Jan 23, 2017 at 9:13 PM
NAMAL
Thanks a lot Steve. The problem is, in my area it is very hard to find a good mechanic who will carryout a good job in cleaning the engine mechanically. If I do a chemical flush and replace the engine oil some what frequently (at about 1500 km for couple of times), will it be a good decision?
Jan 23, 2017 at 9:31 PM
STEVE W.
  • 15,405 POSTS
It should not hurt it. It depends on how dirty the engine is currently and where the deposits are. You could even do the flush run it a bit and do it again. I have always been a fan of, tear it down and clean it because there are areas (piston ring lands) where the flush does not reach very well. But then again I also wear a leather belt and attached suspenders for my pants, really do not like "mooning" the folks. :-)
Where are you located (country and city are fine) maybe someone on here knows of a good shop nearby or at least some to avoid.
Here is a write up on it.
http://www.toyoland.com/sludge.html
Jan 23, 2017 at 11:15 PM
NAMAL
:D yup got it. I am from Colombo, Sri Lanka.
Jan 24, 2017 at 7:30 AM
STEVE W.
  • 15,405 POSTS
Oh right next door.... :-) Sorry to say I know of no shops there...
Jan 24, 2017 at 8:52 AM
