Engine slow turning over
50,000 MILES • 0.5L • 4 CYL • 2WD • MANUAL
KRBLUCKY
  • 27 POSTS
I have a old 38 Bantam, when I turn
Key the motor turns over very slowly.
Has new battery, clean battery terminals, etc.
See video, please help
Thank you
Kenny
Jan 6, 2020 at 8:02 PM
  • 110,248 POSTS
Does this have a 6 volt system or is a 12 volt system? If it is a 6, that is very common. Is the video the MG or the Bantam?
Jan 7, 2020 at 12:38 PM
KRBLUCKY
  • 27 POSTS
Joe hi, its the Bantam, 6 cylinder.
Thank you Kenny.
Jan 7, 2020 at 6:46 PM
  • 110,248 POSTS
Kenny,
No, I meant is it a 12 volt or 6 volt system. Basically, is the battery in the vehicle a 6 or 12v battery? It is normal if for the engine to crank slower with a 6v system.
Jan 8, 2020 at 10:23 AM
KRBLUCKY
  • 27 POSTS
Joe, it's a 6 volt system, it's reversed , black is positive ground.
Kenny
Jan 8, 2020 at 6:48 PM
  • 110,248 POSTS
Kenny,
Honestly, the way it is cranking sounds normal for that type of system. I don't think it will do any better.
Let me know if I can help.
Jan 9, 2020 at 10:00 AM
