Engine similarities?
180,547 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JOSELCANTU
I’ve watched your amazing 5.3 ls Lm7 breakdown playlist, and my question is since my engine is the LC9 that comes from the gmt900. Can I use all those exact parts you received from summit racing or is there some small adjustments or tips I need to look out for to do a build just like yours.
Jan 28, 2026 at 2:35 PM
STEVE W.
  • 15,410 POSTS
They are somewhat similar but they are different generations. The 5.3 in the videos is the later 3rd generation engine while yours is a 4th generation engines. There were a number of changes made in the gen 4 engines like displacement on demand and internal changes in the cam and lifters as a result. There are parts available for them to build some extra power though they are not the same as the LM parts.
Jan 29, 2026 at 1:46 PM
RYAN L
  • 273 POSTS
Thank you for watching the series!
There is a ton of crossover on parts but before you order anything just check with Summit if it fits your engine. They have a really good fit checker on every single parts page.
Best,
Ryan
Jan 30, 2026 at 6:51 AM
