Engine shuts off when clutch is engaged
150,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
ZAKARIYYA GANGAT
Good day. Vehicle listed above (Lite) shuts off when clutch is engaged. At start up the car idles fine but after driving a few meters approaching a stop, engine shuts off as revs drop way below 1,000 rpm's. Sometimes manages to stay on but keeps moving between 500-800 rpm's, not the normal smooth idle. Had a very high idle before then changing TPS caused it to start switching although doesn't idle high anymore. Car has always idled well at start up.
Feb 10, 2020 at 5:21 PM
JOETECHPRO
  • 705 POSTS
Hey ZAKARIYYA GANGAT,
Does the idle change if you press the brake pedal?
Regards, Joe
Feb 11, 2020 at 1:00 AM
  • 55,721 POSTS
This can happen when the clutch disc is starting to fall apart. here is a guide that will help you understand whats going on:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Feb 12, 2020 at 2:22 AM
