Engine shuts off on long idle?
50,000 MILES • 1.2L • 3 CYL • 2WD • MANUAL
AKU
I have this problem with my car. When i drive it without stopping much, the car can keep running for hours on end. But after some hours stuck in traffic, the car starts acting up and turns off by itself abruptly. But if i turn on the ignition it starts without problems, but the car continuously starts shutting off. And this issue stops after i keep the car turned off for more than 2 hours. Please help.
Apr 27, 2023 at 11:36 PM
  • 110,248 POSTS
The Polo isn't offered in the US, but I will try my best to help.
What you described sounds like a failing crankshaft position sensor. When they begin to fail, heat adversely affects them. Since this happens in traffic, that leads me to think the under-hood temperature is higher causing the issue.
Take a look through this link and let me know if anything seems to mirror what you experience:
Let me know your thoughts.
Apr 28, 2023 at 5:12 PM
