the engine will just shut off at high rpm 5000 to 5500 rpm on half to full throttel accelration.it will restart in nutreual and usally when it restart the temp guage dosent work.if the car sits for 6 hours or more and i drive it again the temp guage works again.when the temp gauge stops working my cooloing fans run all the time.it is not throwing a chack engine light and is not storing any codes.all fluid levels are good battery and altonator are good have checked all powers and grounds.have chacked the wiring harness for problems none found .i have checked the connections at the pcm no problems found there either.some times when it stalls and i restart it if i give it more then 1/8 throttel the engine will ping horriable.but after 2 to 3 mins of driving it easy it wont ping anymore but temp gauge still isnt working intil the car sits for atleast 6 hours any ideas i am pulling my hair out!
Sep 8, 2014 at 10:41 AM
