Engine shuts off while driving, code P1300
150,000 MILES • 2.9L • 6 CYL • 2WD • AUTOMATIC
JERRY ROGERS2
Engine starts runs about ten minutes then shuts off code reader shows p1300.
Aug 10, 2018 at 1:10 AM
  • 55,749 POSTS
This code it for the ignition igniter problem. Here is the location so you can change it out and check the connections for corrosion. The igniter is located at the left rear of the engine compartment. Here is the engine wiring diagrams so you can see how the system works and the color wires going into the igniter.
Cheers, Ken
Aug 11, 2018 at 7:00 AM
