Engine shuts down when head lights are on
15,400 MILES • 3.0L • 4 CYL • 4WD • AUTOMATIC
HOOKFòOT
Just purchased the vehicle listed above it is a Prado diesel. it has a problem when I turn the head lights on it cuts out and the oil temperature light comes on.
Dec 27, 2017 at 7:10 AM
KHLOW2008
  • 41,812 POSTS
Hi HOOKFòOT,
There is a fault with the wiring and that is interfering with the power supply for operating the engine.
Perform a scan to check for trouble codes and let us know the exact code if any found.
K H Low
Dec 27, 2017 at 1:17 PM
