Engine shanking while moving initially
15 MILES
RAJUSHIVAG
recently i have changed clutch set, then onwards while moving initially engine shaking a lot, i do not understand why it is happening.
i request your good advise to overcome this issue
early advice will be highly appreciated.
thank you
GV. SIVA KUMAR RAJU
Apr 17, 2013 at 3:53 AM
flywheel is warped. it vibrates till full engagement. you need to replace the flywheel
Apr 17, 2013 at 7:59 AM
