Engine shakes
105,000 MILES • 3.0L • TURBO • AUTOMATIC
AAMIR4X
  • 6 POSTS
My engine shakes very badly when car is at rest. When I apply slight acceleration, the shaking seems to stop. When I gave it to an engine specialist, he checked the whole engine and said he could not find any problem with the engine.
Jul 19, 2018 at 12:18 AM
  • 110,246 POSTS
Based on your description, it sounds like the engine idle speed may be too low. If you noticed this more when using the air conditioning, suspect a bad or dirty idle air control valve (IAC). This component is designed to allow a metered amount of air into the engine when at idle. Additionally, when the air conditioning or other load is placed on the engine at an idle, the IAC should allow additional air to enter to increase idle speed.
The IAC is located on the throttle body of the vehicle. I know this vehicle is a 4 gen 7 series, but I am not able to find the exact model in my manual. However, I have attached a picture or a 745i IAC to help you locate it. Also, you can read through this link which discusses rough idle and idle misfire.
https://www.2carpros.com/articles/engine-vibration-at-idle
Next, often times an engine vacuum leak can cause a rough idle and then is not noticed when the vehicle is moving. In reality, that should set the check engine light to come on and then a code indicating a lean fuel mixture or once specific to a component. Here are directions for checking for a vacuum leak:
Jul 19, 2018 at 1:00 PM
AAMIR4X
  • 6 POSTS
Hi Joe. Thank you very much for your reply. Unfortunately I am just reading it now as I received no notification in my inbox that I got a reply. However, I am not able to locate the IAC. I have included pictures of my throttle body. Please let me know if you can see it. As for the vacuum leak, there are no fault codes showing even when a computer is plugged in to see. The only code I ever remember seeing was 4BD2 ARS Torque request and no mechanic seems to know what that means. I still have the problem and no one has been able to fix it so far. I really look forward to your reply.
Sep 11, 2018 at 10:50 PM
  • 55,540 POSTS
Okay this is a Euro car and does not have an ALDL connector like US based cars do. Also, this car does not have an IAC motor. Lets try doing a compression test to see if you have a low cylinder.
This guide can help as well.
Cheers, Ken
Sep 16, 2018 at 8:23 AM
AAMIR4X
  • 6 POSTS
Hello, thanks for your reply. The BMW mechanic did a compression test and all was fine. They checked the throttle body, injectors and connection lines. He was advising me to change high fuel pressure regulator but he said there was no guarantee this was the issue. Please see the video for a little test I tried. After inserting a cloth into the throttle body, the car stops shaking. I am not sure if that means anything?
Sep 20, 2018 at 7:12 AM
  • 55,540 POSTS
Thanks for the video really helps. It definitely is a mixture issue. This car is a diesel? Have you changed out the fuel filter lately?
Sep 20, 2018 at 9:20 AM
AAMIR4X
  • 6 POSTS
Yes, that is right, it is a 730 diesel. I have changed the fuel filter (genuine). Can i ask what you mean by a mixture issue
Sep 23, 2018 at 11:00 PM
  • 55,540 POSTS
Mixture meaning too much air not enough fuel that is why it run better when you remove the air. It is like it has a leak in one of the turbo intake tubes or a leak in one of the pressure tubes. Can you look using a flashing light to see if you can see anything? You might need to find a smoke machine and use that to find the leak.
Sep 24, 2018 at 4:44 AM
AAMIR4X
  • 6 POSTS
Thanks for the information, I will be taking it to one more mechanic today and will be mentioning the suggestion of a leak to him. I will keep you posted. Once again, thanks a lot!
Sep 24, 2018 at 7:54 PM
  • 55,540 POSTS
Sounds good please let us know.
Sep 25, 2018 at 2:46 AM
AAMIR4X
  • 6 POSTS
Hi Ken, one thing I have discovered today, when I open the engine oil cap, after about two minutes, it stops shaking. This is what I discovered when I was checking for the air leak. Do you think this can be an issue with the engine breather?
Sep 27, 2018 at 2:32 AM
  • 55,540 POSTS
Yes, it can these engine have an air oil separator which is incorporated in the valve cover and it has other parts that go with the system as well.
Crankcase Venting System:
The crankcase vapors (a result of combustion blow-by gasses) are led out of the crankcase and back into the combustion chamber via the intake manifold. The blow-by gasses contain droplets of oil which must be separated. The oil is returned to the sump while the blow-by gasses are led into the intake pipe for combustion.
The engine performance is affected by the introduction of crankcase vapors into the combustion process, particularly in idle speed ranges. This influence is monitored by lambda regulation.
The crankcase vapors are carried from the crankcase and into the cylinder head covers through labyrinth separators (one per cylinder head). The oil which accumulates on the walls of the labyrinth separators flows into the cylinder head via a siphon and from there back to the sump.
The remaining vapors are passed to the engine for combustion via the pressure control valve (5) in the intake manifold. One labyrinth separator with a pressure control valve is integrated in each of the two cylinder head covers.
The throttle valve is controlled so that there is always a 50 mbar vacuum in the intake manifold. The pressure control valve regulates the crankcase pressure to a low 0-30 mbar.
The intake needs to be removed it looks like.
Sep 27, 2018 at 3:40 AM
