engine service soon light dos not turns off after reparation
141,200 MILES
JOFRANCOAC
It was replaced the evaporative fuel sensor, even the fuel lid cap, made its turn up, checked the fuel lines and ther was no leak but hte engine service soon light does not turns off, it was reset with the scanner and nothing, I need to have the new inspection sticker and need to fix this problem, please helpe!
Aug 19, 2013 at 7:22 AM
SATURNTECH9
  • 30,869 POSTS
What is the exact code numbers you have not code descriptions?
Aug 19, 2013 at 8:01 AM
JOFRANCOAC
Hello Friend and thanks for your attention; I don't know the code, but the mechanic has 3 days trying to turn off the engine service soon light in my pontiac Aztek 2003 after replacing the evaporative fuel sensor at the fuel tank, had the tune up, replaced the fuel lid cap, checked the fuel lines and cables, reset with the scanner and nothing is working and I need to turn off this light to get the verification inspection new sticker, can you please help me with this?, Best Regards. Jorge Cobian
Aug 20, 2013 at 3:18 AM
SATURNTECH9
  • 30,869 POSTS
I will help you but the first thing you need to do is get e the exact code numbers?Even if I had the car in front of me I would still need to get those codes.If you don't live in California take it to auto zone and have them read the codes for free.
Aug 20, 2013 at 3:38 AM
JOFRANCOAC
ok. I will get the codes and let you know, thanks!
Aug 20, 2013 at 3:53 AM
SATURNTECH9
  • 30,869 POSTS
Sounds good.
Aug 20, 2013 at 4:02 AM
