Engine runs rough and dies when cold
150,000 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
RAILROADERTWO
  • 42 POSTS
1996 Chevy Corsica 3.1L 150,000 Miles
The Engine runs rough and dies after idling for approximately 2 or three minutes. It only does this when first started when cold, after it warms up no problems.
There are no service engine soon lights
Replaced the lower and upper intake manifold gaskets
Replaced both oxygen sensors
Just Replaced the Coolant temperature sensor
Replaced spark plug wire and plugs
I feel like it's a sensor problem, but don't have a clue which one it might be, I thought it might be the EGR Valve, but I don't know what the symptoms are with those.
This engine runs Great after I restart it and let it warm up a little, , which led me to believe it was the Coolant temp sensor, appears this was not the case. Thank You
May 15, 2015 at 10:20 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge auto parts rent it. clean throttle plate on both sides and iac hole with choke cleaner.
May 15, 2015 at 10:57 PM
RAILROADERTWO
  • 42 POSTS
Thanks, I have my own fuel pressure tester, and I will check the Throttle plate and IAC hole. I have also put on a new fuel pressure regulator, I also did a vacuum check just for grins , was 38 and steady.
May 16, 2015 at 1:32 AM
HMAC300
  • 48,601 POSTS
You need a new vacuum gauge as it should be no higher than 21 at idle or anytime if you mean fuel pressure that may be your problem fuel pressure should be 41-47 psi no lower key on engine off.
May 16, 2015 at 1:52 AM
RAILROADERTWO
  • 42 POSTS
Well, Grin, I could have read it wrong. I will look at it closer next time. Thanks
May 16, 2015 at 2:42 AM
HMAC300
  • 48,601 POSTS
rethinking this it may be the fuel pressure you read and not vacuum which would be to low to run or start the engine.
May 16, 2015 at 4:43 AM
RAILROADERTWO
  • 42 POSTS
I put on a new IAC Valve, did not help, but I have not yet checked the fuel pressure, I did when I was having previous problems that eventually turned out to be a leaking lower manifold gasket, at that time the Fuel Pump Pressure was 38 to 40lbs
May 24, 2015 at 6:01 AM
RAILROADERTWO
  • 42 POSTS
Addition: Two of three Coils have been replaced, swapped the third one with another one, same symptoms.
May 24, 2015 at 6:07 AM
RAILROADERTWO
  • 42 POSTS
Recap: Here is what I have done so far.
Replaced Plug Wires
Replaced Plugs
Replaced Fuel Filter
Replaced Fuel Pressure Regulator 1 yr ago
Checked Fuel Pump Pressure 38 to 40lbs
Replaced Both Oxygen Sensors
Replaced Upper and Lower Intake gaskets
Replaced injector Filters and O-Rings
Replaced Coolant Temp Sensor 3 wks ago
2 Out of 3 Coils Replaced (did swap coils around, no change)
Replaced IAC Sensor
Cleaned the Mass Air Flow Sensor with Sensor Cleaner.
Failing Camshaft Sensor?
May 24, 2015 at 6:27 AM
HMAC300
  • 48,601 POSTS
fuel pressure has to be 41-47 minimum you said it was 39-40 - not enough that is why it's running rough if at all
May 24, 2015 at 6:57 AM
RAILROADERTWO
  • 42 POSTS
I will re-check later, in any case I have ordered a replacement fuel pump.
May 24, 2015 at 8:15 AM
RAILROADERTWO
  • 42 POSTS
Re-tested Fuel pressure at the fuel rail connector , when switch first turned on, 39 lbs, quickly leaks down to 30 or less, is this normal? Maintains 38 lbs when idling. Thanks
May 26, 2015 at 11:45 AM
RAILROADERTWO
  • 42 POSTS
Is the leak down normal, not the pressure, according to service manual, it is too low.
May 26, 2015 at 11:47 AM
HMAC300
  • 48,601 POSTS
you need another pump and filter, it should be 41-47 psi key on only and not drop more than 5 psi in 5-10 minutes
May 26, 2015 at 11:51 PM
RAILROADERTWO
  • 42 POSTS
Put a on a new fuel pump with new pump seal, and 2 new filters, I now have 47 lbs pressure when the ignition switch is turned on, but leaks down to about 38 lbs as before, also only maintains approx 38 lbs when idling, and the rough idle is still there only when cold, for a few couple minutes. I am at a loss for a cause. It acts like a bad coolant temp sensor, but I just replaced that a month ago. What does the fuel pressure regulator do? Thanks
Jun 3, 2015 at 6:32 AM
HMAC300
  • 48,601 POSTS
it should only leak down about 2-10 psi also check for a vacuum leak. it may be a vacuum leak like a hose off becaue the computer picks I tup as lean and richens the mixture to stop running rough so check for that and then do check in pic except for pump
Jun 3, 2015 at 6:45 AM
RAILROADERTWO
  • 42 POSTS
Here is an updated symptom description:
When car is first started, it will idle just fine for about 5 minutes, at which time it starts to run very rough, for about a minute or two, I'm guessing, did not time it. then the engine will rev up above normal idle and then return to normal idle. I have not yet got around to run another vacuum test, will do that in a day or so. This is my son's old piece of junk, He (we) can't afford to buy him another car, so will just have to keep at it till I find out what is wrong with it. It runs great except for that little short spell it has every day.
Jun 7, 2015 at 12:51 PM
HMAC300
  • 48,601 POSTS
these were known for inlet port gasket problems but leaked anti freeze, check at front an drear of manifold if you see antifreeze at corners then it probably needs them. without actually seeing this and testing I can give no other suggestions. if fuel is ok and pressure doesn't drop like I stated which if it does it may be a vacuum hose leading to regulator or bad regulator.
Jun 7, 2015 at 11:54 PM
RAILROADERTWO
  • 42 POSTS
Well I replaced both manifold gaskets, and there appears to be no visible signs of any antifreeze leaking outside or inside the engine now, it was leaking on the outside before. I checked the vacuum again and it is steady at 15hg when engine first started at normal idle, however after a few minutes the engine starts running very rough, and sometimes it dies, and the vacuum drops to near 0, for a minute or so, when restarted at idle, then it recovers to 15hg again. so during this time of rough idle, I assume something is causing a vacuum leak.
Jun 9, 2015 at 9:02 AM
HMAC300
  • 48,601 POSTS
check for a clogged converter if at 15" that si a sure sign of it. are you sure you don't have a 420 or 430 code?
Jun 10, 2015 at 12:18 AM
RAILROADERTWO
  • 42 POSTS
For the what it's worth department, it was the upstream oxygen sensor I had replaced less than a year ago.
Jul 17, 2015 at 11:23 AM
