engine runs rough
124,000 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
THOMASMCBRIDEJR
engine feels like it is missing when idling.
Sep 12, 2020 at 11:16 AM
  • 110,248 POSTS
If the check engine light is staying on or flashing, you should start by having the computer scanned for diagnostic trouble codes. Most parts stores will do it free of charge.
If the light isn't on, start by checking for engine vacuum leaks. Here is a link that explains how that is done:
Let me know if you have already checked for codes. Also, let me know if you have other questions.
Sep 12, 2020 at 12:03 PM
THOMASMCBRIDEJR
Thank you for your advice, hopefully this will help resolve this problem. Tom.
Sep 12, 2020 at 10:55 PM
  • 110,248 POSTS
Hi Tom,
You are very welcome. If you have a chance, let me know what you find or if you have other questions.
Sep 13, 2020 at 12:37 PM
THOMASMCBRIDEJR
Have not found vacuum leak yet, still looking. Thanks, Tom
Sep 14, 2020 at 5:52 AM
  • 110,248 POSTS
Tom,
When you check for the leak, pay special attention around the intake manifold gasket. They are known to leak. Note there is an upper and a lower intake. The only pic I could find was the intake being removed. I highlighted the areas to check.
Sep 14, 2020 at 11:53 AM
