Engine runs hot
205,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
RICKYSH11
  • 75 POSTS
The engine has begun to run hot mainly when at idle. I noticed however that the fan runs at start and continues to run until the temperature gauge gets close to overheating. The fan would just stop running at that point and the vehicle overheats. I replaced the fan clutch about a year ago. At that time I was getting a P0526 code. After replacing it I have gotten a P0480 code so I replaced the fuses but the fan now stops when the temperature rises. What can be the possible causes?
Oct 9, 2018 at 4:05 PM
Good morning.
Okay, I had a couple of these with the same issue. What I did was had to have the PCM updated with the most current version from GM. they had similar issue with a lot of these and the updated software took care of the issue.
Have you ever had an update on your PCM?
Description
Symptom/DTC P0480
Descriptor
Engine Cooling
Probable Causes
Additional DTCs Present
High Speed Fan Relay
Low Speed Fan Relay
Powertrain Control Module (PCM)
S/P Fan Relay
Series/Parallel (S/P) Fan Relay
Oct 9, 2018 at 10:58 PM
RICKYSH11
  • 75 POSTS
Thanks for such a quick reply. I have not had an update to the PCM, can any shop do it or would it have to go to GM dealer?
Oct 10, 2018 at 8:06 AM
Some shops can do the update as long as they have the scan tool that can perform this. Call around and ask. The last resort is the dealer but they are the highest price.
Oct 10, 2018 at 8:16 AM
