Engine running rough when AC is on...
142,000 MILES
SONYAMARIETX
Had the fan replaced 2 years ago, being the engine would start running really rough, would turn off car and restart, the engine would some how reset and run fine for a few minutes. Had the problem checked was the fan going out...Somehow the computer shuts the engine down. Now having same issue when I turn on the AC, the engine runs rough and makes a noise with hardly any power. But when i shut off and restart, it runs fine, till I put AC back on? Any thoughts?
Jun 18, 2013 at 7:10 AM
CJ MEDEVAC
  • 11,000 POSTS
THIS SOUNDS LIKE THE A/C COMPRESSOR IS LOCKED UP
AS LONG AS THE A/C CLUTCH IS NOT ENGAGED, THE PULLEY TURNS FREELY
WHEN YOU ENGAGE THE A/C (OR ANY HEAT MODE THAT INCLUDES "DEFROST"---"DEFROST" MODES MAKE THE COMPRESSOR ENGAGE TOO)......WHAT IS PROBABLY HAPPENING IS THE COMPRESSOR CANNOT TURN, IT'S PULLEY SITS STILL AND THE BELT WILL NOT ROLL OVER THE PULLEY, THIS FRICTION INSTANTLY BOGS DOWN THE MOTOR
HAVE SOMEONE WATCH THE A/C PULLEY AS YOU ENGAGE THE A/C TO VERIFY MY HYPOTHESIS
RETURN WITH NEWS
THE MEDIC
Jun 19, 2013 at 1:42 PM
SONYAMARIETX
HI,
Had everything checked. a/c compressor was perfect, pulley's fine. Turned out to be a few bad ignition coils. Had plugs replaced last year, didn't replace coils. So replaced all 8 and running great.
Jul 1, 2013 at 3:30 AM
CJ MEDEVAC
  • 11,000 POSTS
THAT'S GOOD NEWS!
HOPE IT WASN'T REAL EXPENSIVE REPLACING THE COILS
THE MEDIC
Jul 1, 2013 at 6:31 AM
