Was driving and hit a hard bump on the shoulder and all the sudden the engine is running rough, feels like it's missing. Check plugs and wires. Still running rough. After talking over the issues, rough/missing on acceleration, with a couple fairly knowledgeable guys as well as a brief scent of the catalytic converter (rotten eggs) smell, we cut the converter off to test it. That's not the issue. Kind of stuck at this point and now considering coil pack, Egr valve, or throttle position sensor. What could I have broken, upset, or shaken loose in a hard bump that would be causing the rough running? Also, when I just lightly feather the accelerator, the engine revs high and low. Check engine light is not on.
Sep 18, 2019 at 8:25 PM
