engine running rough
200,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
BARFOOT50
the IAC has been replaced and the engine still runs rough and has gas smell found bad intake hose and replaced it. do not know if some rubber got into plenum. this is an S-10 Blazer
May 2, 2017 at 12:08 AM
HMAC300
  • 48,601 POSTS
check for a blown gasket under TBI unit they like to do that. just use choke cleaner and replace any soft vacuum hose like going to PCV and map sensor as they suck together and do not let MAP work right.
May 2, 2017 at 5:57 AM
