engine running/idling rough
165 MILES
ARAUCANO
the car started to idle real rough when I was backing out of a parking stall at a local restaurant, so I stop immediately and proceeded to go forward and same thing continue the rough idling, I drove it about 3 city blocks, and as I was coming to a stop the engine felt like it was going to stop.
Apr 25, 2013 at 4:52 PM
CARADIODOC
  • 34,412 POSTS
Without knowing any other details or even which engine you have, I'd start with the basics, spark plugs and wires. Some engines use a coil pack and one bad ignition coil in it will kill two cylinders. Check for diagnostic fault codes too. Chrysler makes that real easy. Cycle the ignition switch three times from "off" to "run" within five seconds, leave it in "run", then watch the numbers show up in the odometer display.
Apr 25, 2013 at 5:44 PM
