Installed 351w crate engine. Engine had not been run for ten years. Have installed new pointless distributor, new fuel pump, new wiring and plugs,checked compression (118-120), timed and wired for 351 also tried wiring for 302 cam (definitely not 302), set floats on Edelbrock 4bbl. All vacuum ports plugged (except vacuum advance ).
Still rough idle, almost like a miss, backfires through carburetor and exhaust with manual acceleration.
Would appreciate your advise.
Thanks, Tom
Thanks, Tom
May 11, 2018 at 2:44 PM
