weak spark at spark plugs pail red not blue low voltage at crankshaft sensor four pin connector pin one3.10 pin two 0.01 pin three 7.21 pin four 7.19, voltage at both wire at injection connectors 12.97 volts at both wires on# 1 12.93 on# 3 12.90 on# 5 AND 2 4 AND 6 new icm/ new coils new fuel pump less then 5000k on fuel injection /tps / iac valve new coolant temp. sensor this started with engine bogging down at acceleration but it would come out it when you back off it, then the engine would start but stop shortly after now it will not start at all car has 135000k engine has 19000k need help is this a bad ecm?
Jul 24, 2013 at 5:37 PM
