Good evening.
When you crank the engine, does the tachometer move up a little while cranking? It may be the crank sensor that is not sending a signal to the ECM.
REMOVAL
1. Raise and support vehicle.
2. Disconnect crankshaft position sensor electrical connector from the wiring harness connector (Fig. 4).
3. Remove crankshaft position sensor retaining bolt.
4. Pull crankshaft position sensor straight up out of the transaxle housing.
NOTE: If the removed sensor is to be reinstalled, clean off the old spacer on the sensor face. A NEW SPACER must be attached to the sensor face before installation. If the sensor is being replaced, confirm that the paper spacer is attached to the lace of the new sensor (Fig. 5).
Images (Click to enlarge)
Jun 11, 2018 at 9:00 AM
