Engine revs up and down at idle with code p1514 and p0420.
2003 SUBARU LEGACY
90,000 MILES • 6 CYL • AWD • MANUAL
CHAD JACKSON
  • 6 POSTS
Car revs up and down between 1000 and 2000 rpms at stop or idle....no real loss of power at highway speed. In second gear at full throttle i get a slight sputter or miss
Feb 22, 2015 at 8:34 AM
  • 110,244 POSTS
P1514 is related to the idle air control valve which is what is most likely causing the idle issues. That would be the first thing I check. As far as the P0420, that is related to the catalytic converter working below expectations. Fix the IAC first and see if that eliminates the P0420 problem. Let me know if that takes care of it.
The IAC is located on the throttle body. It requires the removal of two screws and disconnection of wires to it. Then it is just a matter of removing and replacing.
Feb 22, 2015 at 12:20 PM
CHAD JACKSON
  • 6 POSTS
i changed the iac valve....i tried to reset the codes but they come right back...today a new code of p1443 showed up....the car started this morning and cut right off....i pumped the gas a few times and it started....when i started driving and put it in neutral the car reved all the way to 4000rpms for a few seconds and then started surging from 1000rpm to 2000rpms...i noticed in second gear at full throttle it had a little sputter or hesitation to it for a breif second...
but it continues to rev up and down from 1000rpms to 2000rpms at idle or in neutral even after i replaced the idle air control valve
Feb 23, 2015 at 3:01 AM
  • 110,244 POSTS
Have you checked if the IAC is getting power?
Feb 23, 2015 at 3:04 AM
CHAD JACKSON
  • 6 POSTS
no i havnt...should i do that with a test light or something else?
Feb 23, 2015 at 3:07 AM
CHAD JACKSON
  • 6 POSTS
i tested it and it has power going to it
Feb 23, 2015 at 6:06 AM
  • 110,244 POSTS
Okay, it is getting power. Do this now. Remove the IAC and have a helper turn the key from off to the run position (engine off) and see if there is movement in the pintel.
Feb 24, 2015 at 9:41 AM
CHAD JACKSON
  • 6 POSTS
i did that...the iacv prong does move in and out
Mar 11, 2015 at 4:49 AM
  • 110,244 POSTS
Have you checked for vacuum leaks?
Mar 11, 2015 at 11:47 AM
CHAD JACKSON
  • 6 POSTS
yes..no vacuum leaks
Mar 31, 2015 at 9:43 AM
