Engine Replacement Labor Time?
246,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
NIGHTHAWK4570
  • 24 POSTS
Could any of the experts on here provide me with what the estimated labor hours are and from what guide that time is from to replace the engine in the truck listed above?
The truck has a 3.0-liter engine with V as the engine identification letter in the VIN.
I've received quotes from two different, independent repair shops in the area where I live. One shop quoted me $1,249.00 at a $119.00/hour labor rate while the other shop quoted me $1,600.00 at a $90.00/hour labor rate. This price difference makes no sense to me, and I'd just like to be an informed consumer going forward as I request quotes from other repair shops.
Dec 18, 2022 at 12:30 PM
  • 55,721 POSTS
There are some factors that change the pricing. Here are the hour times which you can use by multiplying the shop rate
Complete Assembly With Transfer Of Parts 9.2 hrs@ Shop rate.
Includes: Transfer All Fuel & Electrical Units. Does Not Includes Transfer Of Optional
Equipment.
NOTE(Optional Labor)
With AC, Add 0.8 hrs@ Shop rate.
Complete Assembly Without Transfer Of Parts
Auto Trans 6.7 hrs@ Shop rate.
Does Not Include: Transfer Of Any Part Of Engine Or Replacement Of Optional Equipment.
Manual Trans 6.7 hrs@ Shop rate.
Note (Optional Labor)
Long Block 13.2 hrs@ Shop rate.
Includes: R&R Engine & Transfer All Necessary Components Not Supplied With Long Block.
With AC, Add 0.8
Short Block 16.2 hrs@ Shop rate.
Includes: R&I Engine And Replacement Of All Necessary Components.
To R&R Grind Valves, Add 6.2 hrs@ Shop rate.
With AC, Add 0.8
Overhaul/Rebuild Engine, Overhaul 28.0 hrs@ Shop rate.
Includes: Disassemble & Clean Engine, Ridge Ream & Hone Cylinders, Fit Pistons, Rings, Pins, Main & Rod Bearings, Grind Valves & Tune-Up
Let us know if you need any other information to get the job done.
Dec 19, 2022 at 2:56 AM
