engine replacement
130 MILES • 1.9L • 4 CYL • TURBO • 2WD • MANUAL
KEITH PRESTON
My engine is a BLS code. Can you replace with any other codes having problems finding one with the same code?
Mar 17, 2022 at 6:43 PM
SQM
  • 6,383 POSTS
Unfortunately, the engine code has to match in order for it to be a suitable replacement. The issue is the code will determine how the other components function and the computers will be different.
So, finding the engine with the correct code is necessary.
Also, you have listed the vehicle to have a 1.9L engine, on 2009 there were no 1.9L for the Jetta's.
Mar 18, 2022 at 8:25 AM
