Engine Swap?
1 MILES • 2.4L • 4 CYL
CHRYS99
I’d like to know if you can swap a 4T1BE engine with a 2AZ-FE engine.
Apr 16, 2024 at 4:11 PM
  • 55,746 POSTS
One is a 4 cylinder, and the other is a 6 cylinder so I don't recommend doing this, it would be cheaper to get the car with the 6 cylinder already in it. The wiring harness, exhaust system, PCM, engine mounts, too many things to list will need to be changed.
Apr 17, 2024 at 3:25 AM
