can a 2002 Mitsubishi Montero 3.5l engine replace a 2001 XLS model?
Jul 27, 2022 at 10:41 AM
SQM
✓Experienced Mechanic
Both the 2001 and 2002 Montero uses the same 3.5L V6.
So as long as both of the vehicles have the 3.5L (not the 3.0 Montero Sport), it will work.
I have attached the engine replacement steps below for your reference.
Let me know of any questions.
Images (Click to enlarge)
Jul 27, 2022 at 1:31 PM
The 3.0 is different in several ways. Can it be done, anything is possible. However, you will need to change computers, wiring harnesses, engine mounts, (and trans I believe the bolt pattern is different) vacuum hoses, and anything you can think of.
