Would it be worth replacing this engine with a new one?
66,000 MILES • 1.5L • 4 CYL • TURBO
MARCUS321
I am asking if it would be worth replacing this engine with a new one. cylinder # 2 is defective along with a piston and crankshaft issues. It would cost me $6,000.00. Is it worth it?
Sep 30, 2022 at 10:54 PM
  • 55,728 POSTS
With only 66,000 I would say replace the engine, there is no way you could replace this car for that much, can I ask what happened to the engine, did it overheat or?
Oct 1, 2022 at 4:34 AM
1951MARC
This is what I am being told. #2 cylinder no compression. scoped motor crack in top of piston. Leak down into crankcase. recommend new motor.
Oct 1, 2022 at 9:37 PM
