I want to replace a blown engine. What other models and years are compatible with my truck (listed above)?
Jan 2, 2018 at 10:41 AM
✓Experienced Mechanic
Good evening.
all the three liter engines from the ranger and the Mazda equivalent will work. you will only be able to use the long block. you will need to strip yours down and change over all the externals to the donor.
Jan 2, 2018 at 11:13 AM
CARLOS37USER
MEMBER
does that include a 2000 Mazda sedan 3.0 ? Thank you for your informative answer.
