What tools will I need to remove the engine?
10,000 MILES • 2.7L • AUTOMATIC
ARIANADANIELLE5345
  • 402 POSTS
Engine removal.
Aug 11, 2024 at 6:54 AM
ARIANADANIELLE5345
  • 402 POSTS
And what are the steps to do so?
Aug 11, 2024 at 9:31 AM
  • 110,246 POSTS
Ariana!!!! It is so good to hear from you. I hope you are doing well.
Anyway, you need a lot of tools. LOL You will need an engine hoist for sure because this one comes out from the top. Other than that, standard tools will do the job. However, before I jump in, I need to know if it is a 4wd or not. That will make a few differences.
Let me know and I'll get the directions to you. And hearing from you has just made my day. Believe me, I needed it. LOL
Aug 11, 2024 at 12:59 PM
ARIANADANIELLE5345
  • 402 POSTS
lol thank you! I appreciate that. And yeah, I have a cherry picker from when I did my Explorer engine. I have an engine stand too. It’s a 4x4 manual.
Aug 11, 2024 at 11:57 PM
ARIANADANIELLE5345
  • 402 POSTS
I accidentally put automatic in the description but it’s a manual.
Aug 11, 2024 at 11:58 PM
  • 110,246 POSTS
Okay, I have the directions below for removing the engine. It looks like a straightforward job. Just take your time. I don't want you getting crushed by the engine. LOL
Take a look through the directions and let me know if they help or i you have questions.
Take care and Welcome Back!!!
Aug 12, 2024 at 12:38 PM
ARIANADANIELLE5345
  • 402 POSTS
Okay, thank you!
Aug 13, 2024 at 2:34 AM
ARIANADANIELLE5345
  • 402 POSTS
Remove transmission completely? Or just separate it from the engine?
Aug 13, 2024 at 2:37 AM
  • 110,246 POSTS
Just separate it from the engine. You should be able to get to all the bell housing bolts, It may be a bit tight at the top.
Take care and Happy Birthday!
Aug 13, 2024 at 1:22 PM
ARIANADANIELLE5345
  • 402 POSTS
Thank you!
Aug 16, 2024 at 2:04 AM
ARIANADANIELLE5345
  • 402 POSTS
Everything is done except I am turning and turning the flexplate but don’t see any torque converter bolts. Am I missing something?
Aug 16, 2024 at 6:01 AM
  • 110,246 POSTS
If this is a manual transmission, it won't have a torque converter. The transmission will come out. Once it is out, then you unbolt the clutch cover/pressure plate from the flywheel.
I attached an exploded view below. Let me know if this helps.
See pic below.
Aug 16, 2024 at 2:04 PM
ARIANADANIELLE5345
  • 402 POSTS
Lol yeah I figured it out. Never really worked on a manual transmission before. Thanks for your help!
Aug 17, 2024 at 1:54 AM
  • 110,246 POSTS
You are very welcome. When you reinstall it, you will need a tool to align the splines of the clutch disc.
Let me know if you run into any trouble.
Aug 17, 2024 at 12:09 PM
