No problems yet, just can you tell if an engine is getting old and tired before it does blow? wanting to know how much it will cost.
Jan 20, 2018 at 10:59 PM
SATURNTECH9
✓Experienced Mechanic
If it is burning a lot of oil that is one sign. also if it was running like it was not running on all the cylinders.That could be a sign but not always a mechanical issue. If it is running good and not burning a lot of oil then I would not worry about it. If it were to just blow there usually is not a whole lot of warning in that case.
