Engine rattling
150,000 MILES • 2.1L • 4 CYL • 2WD • MANUAL
NICKYANC
Engine rattles at low acceleration.
Dec 31, 2017 at 3:20 AM
  • 31,937 POSTS
This may be ignition related pre-ignition knock due to incorrect timing. Your engine has a knock sensor that detects engine knock and sends a signal to the PCM to correct ignition timing, this knock sensor may have failed. Get a scan to see what if any codes are set. failed knock sensor will set a code and not all codes will set a check light. Let me know what codes are set to assist further.
Dec 31, 2017 at 9:50 AM
RENEE L
  • 1,260 POSTS
Hello NICKYANC,
I am sending you a link that if you decide to conduct the scan yourself will be a great help to you. The link features an article with written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the code number(s) please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Jan 1, 2018 at 6:24 AM
