Codes P1805, P0102, P0113 and Engine rattles?
100,000 MILES • 4.0L • V6 • AUTOMATIC
ARIANADANIELLE5345
  • 402 POSTS
Engine rattles and my code reader says P1805 current, P0102 current, P0011 3 times, and P0113 1st trip. Is it a broken timing component?
Apr 25, 2025 at 4:25 PM
MECHTRIX
  • 566 POSTS
Yes the poo11 code is the most important one in the list especially if the engine has a rattle.. it indicats a problem with the vvt variable valve timing ...it usually means that the vvt oil control solinoid might be broken might be time to replace it ...the parts pretty cheap...also ..as a side note it's not good to drive the car till its fixed might damage somthing ..but the rattle should go away and it should run smooth again once the problems is solved. Also the po102 code is a maf sensor and the po113 code is a ait"..or intake air tempsensor code.. these two somtimes go away after vvt problem is fixed so fix it first clear the code and keep an eye on it for a while ..Good luck
Apr 27, 2025 at 6:21 AM
  • 55,560 POSTS
It looks like you have two or three problems, the first is the MAF sensor needs to be replaced, or you have a crack or the air intake tube is disconnected between the MAF sensor and throttle body.
This guide can help:
P1805 Brake Switch or Step Motor Circuit (often Transmission-related)
P0102 Mass Air Flow (MAF) Sensor Circuit Low Input
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High Input
P0011 Intake Valve Timing (VVT) Over-Advanced (Bank 1)
If the intake tube is good, I would replace the MAF sensor and then clear the codes, please start new threads for the P1805 and P0011 codes separately. Here is the sensor in question. Check out the images (below). Let us know how it goes.
Apr 27, 2025 at 6:30 AM
ARIANADANIELLE5345
  • 402 POSTS
I had a feeling, so I went with it and tore it apart. My feeling was right, chain guide is broken. That’s what was rattling. Bought the new Cloyes set. How do I time it? It has to be in top dead center before I take the chains off, right? Also, are any of the timing bolts torque to yield? Or can I reuse them?
Apr 28, 2025 at 12:09 AM
ARIANADANIELLE5345
  • 402 POSTS
Oh and intake tube had a crack in it so that’s probably where that code came from.
Apr 28, 2025 at 12:10 AM
ARIANADANIELLE5345
  • 402 POSTS
Also, it was the tensioner that ended up causing the problem because I can literally depress the plunger by hand with ease. So, since it was the tensioner, is it necessary to replace the phasers too? The set I got is without phasers because the one with was over a grand.
Apr 28, 2025 at 12:19 AM
  • 55,560 POSTS
Good find on the cranked intake tube, that will cause the:
Yep, I would put the engine on TDC before taking the engine apart unless the chain it not turning the camshafts, if this is so the engine will most likely need to come apart because of bent intake or exhaust valves. Can you upload images of the problem so I can be sure?
Apr 28, 2025 at 4:06 AM
ARIANADANIELLE5345
  • 402 POSTS
Here’s a video.
Apr 28, 2025 at 10:30 AM
ARIANADANIELLE5345
  • 402 POSTS
And here’s a picture of one of the broken guides.
Apr 28, 2025 at 10:32 AM
ARIANADANIELLE5345
  • 402 POSTS
The chain turns the camshafts, but the chain skips every other rotation around the top right cam phaser because the primary tensioner is bad. So, I’m assuming that’s why my reader picked up the advanced intake timing code.
Apr 29, 2025 at 12:41 AM
  • 55,560 POSTS
Yep, good find on the timing chain issue, I don't like hearing that the chain skips though, you could have bent valves, also can I ask which phone you used to upload the video? It does not work, and I want to tell the webmaster of the site. When you get the timing chain back together, crank the engine over to see if you have compression or not.
Please go over this guide and get back to us.
Apr 29, 2025 at 3:45 AM
ARIANADANIELLE5345
  • 402 POSTS
How do I install the new kit? Since it skipped don’t I have to retime it? And I have the new iPhone. It’s the 16 I think.
Apr 29, 2025 at 10:11 AM
ARIANADANIELLE5345
  • 402 POSTS
The passenger side cam timing mark is off from the other side and the crank. The two on the driver's side are on their marks and so is the crank. The passenger side, not so much. The first pic is passenger side. Second is crank and third is driver side. I used my borescope to check valves, and they seem fine from what I can see.
Apr 29, 2025 at 10:45 AM
  • 55,560 POSTS
New video format thanks. That is good news that the valves are okay. Here is how to time the engine crankshaft and camshafts. Check out the images (below). Let us know how it goes.
Apr 30, 2025 at 3:41 AM
ARIANADANIELLE5345
  • 402 POSTS
I’m not sure though because my borescope isn’t super clear. How do I move that one camshaft though? Because only one is off the mark. Do I just loosen the caps and move it back?
Apr 30, 2025 at 5:48 AM
ARIANADANIELLE5345
  • 402 POSTS
Or do I have to rotate it? I’m not sure where to go from here and can’t seem to find any info online.
Apr 30, 2025 at 12:37 PM
ARIANADANIELLE5345
  • 402 POSTS
Okay, I unbolted the caps and moved the cam, but to put the caps back on with the camshaft on the timing mark, I would have to force it.
May 1, 2025 at 1:21 AM
  • 55,560 POSTS
I don't understand what you mean by "I would have to force it"? did the camshaft not bolt down fully?
May 1, 2025 at 2:58 AM
ARIANADANIELLE5345
  • 402 POSTS
For the timing marks to match up the cam caps don’t fit. For them to fit on top and the bolts to be able to reach the head, it has to be out of time. I’m thinking it’s probably because there’s no tensioner. So maybe after I install the chain and release the pin in the new tensioner it should spring it into place?
May 1, 2025 at 3:22 AM
ARIANADANIELLE5345
  • 402 POSTS
Actually no because the timing marks are for before chain installation. I don’t know how to explain it. Like the way the valves are on the camshaft lobes they don’t allow them to be on time for me to be able to tighten the caps.
May 1, 2025 at 3:24 AM
  • 55,560 POSTS
Could it be the valves are contacting the pistons? Is the engine on TDC when you line up the camshaft marks?
May 2, 2025 at 2:33 AM
ARIANADANIELLE5345
  • 402 POSTS
Yes, it was in top dead center before I removed the chains, but it’s just because that one jumped so that one is off so I’m just going to turn it and put the chain on and then tighten the cap down. Will that mess something up?
May 2, 2025 at 9:20 AM
ARIANADANIELLE5345
  • 402 POSTS
First pic is driver side. Both in time. Second pic is crankshaft, in time. Third pic is passenger side cams where the tensioner that was on the chain guide failed. Left one slightly out of time but the right one is the one I’m talking about. This is what it looks like with the caps being able to go down flush with the head. If I were to take the caps off and move it to match the timing marks, I wouldn’t be able to push the cams back on because of the way the cam lobes end up positioned when I move it.
May 2, 2025 at 9:33 AM
  • 55,560 POSTS
I would try moving the crankshaft off of TDC about 15 degrees and then try rotating the camshafts, they should be safe at this point, then when the camshafts are on the marks move the crankshaft back to TDC. The camshafts should turn freely except for the pressure of the valve springs.
May 3, 2025 at 4:26 AM
ARIANADANIELLE5345
  • 402 POSTS
What is the torque spec for the crankshaft/harmonic balancer bolt?
May 28, 2025 at 11:28 AM
  • 55,560 POSTS
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
May 29, 2025 at 3:38 AM
