Transmission will not go into fifth gear and knocking noise when traveling over fifty mph
110,000 MILES • 1.2L • 2WD • MANUAL
JULIE GARDNER
Two problems I cannot get into gear. Other problem at high speed over 50 mph makes a roaring knocking noise. Oil is okay and temperature.
Jan 22, 2019 at 12:53 AM
  • 55,746 POSTS
It sounds like the clutch is going out can I ask how hard is it to put into the other gears? Can you please shoot a quick video with your phone so we can hear the noise, that would be great. You can upload it here with your response. Here is a video that show the symptoms of the bad clutch
https://youtu.be/EpBMj5ZY_bo
Jan 23, 2019 at 4:16 AM
