Engine problems and weird noise
67,000 MILES • 1.6L • 4 CYL • AUTOMATIC
DESIREE MARIE GALLEGOS
Having trouble with my car listed above LT model . Hesitation comes and goes but getting worse , loss of power , misfiring . Check spark plugs, was oil in one of the wells . Cleaned out and changed o-rings and valve cover gasket , flex pipe has been changed , catalytic converter changed. What could be the problem? Also hearing this noise . It comes and goes . Mainly when A/C is on .
Aug 9, 2019 at 11:43 AM
SCGRANTURISMO
  • 4,897 POSTS
Is your vehicle's Malfunction Indicator Lamp (MIL) or "check engine" light illuminated? If so could get the Direct Trouble Code(s)(DTC)(s) for us? Here is a link down below for you if you are unfamiliar with how to do it.
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 9, 2019 at 5:56 PM
Yes I have and the codes are coming up as both of my o2 sensors .
Aug 11, 2019 at 11:39 PM
Here are a few videos of the noises:
Aug 11, 2019 at 11:42 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Can you give me the DTC numbers please. They will have a letter, probably a P, then four numbers afterward.
Thanks,
Alex
2CarPros
Aug 12, 2019 at 1:35 PM
