Engine problems
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARLA REED
  • 27 POSTS
Have to hold the pedal to floor to start, idles fine, does when you put it in gear. No codes flashing no dummy lights on. New fuel pump.
Sep 27, 2018 at 10:24 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
It seems you might be having an issue with you throttle position sensor. It is located on the throttle body. I have attached a picture and the sensors values when tested. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Sep 27, 2018 at 10:41 AM
CARLA REED
  • 27 POSTS
Thanks so much for information. I will give that a try.
Sep 27, 2018 at 2:06 PM
DANNY L
  • 5,648 POSTS
You are welcome!
Let me know what happens and if you have any further questions.Thanks again for using 2CarPros.
Danny-
Sep 27, 2018 at 2:38 PM
