No spark from the distributor
346,322 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MALETSATSI
No spark on the engine engine doesn't turn. there is no spark coming from distributor.
May 22, 2019 at 10:43 PM
  • 110,248 POSTS
Welcome to 2CarPros.
First, when spark is lost, my first suspect is always a bad crankshaft position sensor. Take a look through these links. The first describes the component I mentioned. The second link describes symptoms, and the third shows in general how to replace one.
This specific vehicle isn't offered in the US, so my technical information is limited. However, take a look through the links and let me know if it helps.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
_____________________
Let me know if this helps.
May 23, 2019 at 10:33 AM
