Will not stay running
175,000 MILES • 5.9L • V8 • 4WD • AUTOMATIC
RAYRANGEL0303
Turns on for 2-3 seconds and then shuts off after that. Checked and cleaned sensors but still same. replaced fuel pump and filter still acting the same.
May 6, 2021 at 2:06 PM
  • 55,743 POSTS
Can I ask if the security light is flashing? If so this will cause the engine to start and then just shut off like you have described. I would do a hard system reboot, remove the negative battery cable and hold it to the positive post for 1 minute then reconnect. This will discharge all capacitors so the system can come back online. This guide can help as well:
https://www.2carpros.com/articles/how-to-reset-a-security-system
If not this is common when you have a vacuum leak or the throttle bore needs to be serviced. here are three guides to go over when fixing the problem:
and
https://www.2carpros.com/articles/stall-at-idle
and
May 11, 2021 at 2:47 AM
