Engine sputtering
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAN SKITCH
When I press on the acceleration it sputters a lot. Almost like it is going to stall, but not quite.
Really bad when just starting out, or going up hill. Seems alright once I hit about fifty mph (eighty kph).
I have included a video.
Jan 6, 2018 at 6:42 PM
  • 55,594 POSTS
Nice work on the video it the only way to go. It looks like the engine needs a set of spark plugs to start off. Here is a guide to help you with that:
https://www.2carpros.com/articles/how-to-change-spark-plugs
If the plugs are new already the next please I would go is the fuel pressure. Here is a guide to help you with that as well:
Lastly, I would check the exhaust to see if it is plugged not allowing the exhaust to exit the engine. Here is a guide to help you confirm:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please run down these guides and report back
Cheers, Ken
Jan 7, 2018 at 12:21 PM
