Idles low and rough
75,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
SHAWN2376
When i start it the motor idles low and rough and when i give it gas it bogs way out and barley runs. i changed plugs they were awful, but it didn't help.
Feb 27, 2019 at 12:03 PM
  • 110,248 POSTS
If the check engine light staying on when the engine runs? If it does, you first need to scan the computer to identify diagnostic trouble codes. Here is a quick video that shows how that is done:
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner. However, often times a parts store will do it for free. If the car is safe enough to drive, that is what I would suggest.
Now, the description you gave can be many different things. For example, low fuel pressure, a major engine vacuum leak, a plugged catalytic converter and the list goes on.
Take a look through this link:
https://www.2carpros.com/articles/engine-vibration-at-idle
Now, what I would suggest is checking fuel pump pressure, check for a vacuum leak, and check for a plugged catalytic converter. I will provide links to help you through these tests.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/catalytic-converter-replacement
_____________________________
Let me know if this helps. Also, if you have found diagnostic trouble codes, let me know what they are because it will eliminate a lot of testing. I will be able to focus on once specific components.
Feb 27, 2019 at 12:34 PM
