engine problem
122,000 MILES
STORMRAGE
i have a 1993 honda civic lx carburetor type, my problem is when I hit the accelerator pedal fast reaching the rpm to 3, it seems that it will stop a bit on 1 or 1.5 then proceed. What would be the problem?
Apr 28, 2013 at 9:13 AM
FREEMBA
  • 1,152 POSTS
sounds like what is called a "flat spot' in the carburetor. This is a problem with the accelerator pump in the carb.
However, try cleaning the carb. with carburetor cleaner. If this works then, problem solved. If not, then a carb overhaul may be in your near future.
Apr 28, 2013 at 9:33 AM
STORMRAGE
Hi freemba,
Thanks for the reply, I already cleaned my carburetor 2 months ago, is it already dirty again? Its so annoying when I pass an uphill and when its traffic as soon as I step on the pedal I tend to loose power and restart.
Apr 28, 2013 at 12:22 PM
FREEMBA
  • 1,152 POSTS
Your carb is not likely clogged again. must likely problem ia a faulty accelerator pump i the carburetor. you'll have to have a carb overhaul to correct this problem.
May 2, 2013 at 10:42 AM
STORMRAGE
thank you so much sir for the advice, it was indeed a great site to have an expert that I have been looking on the internet.
May 2, 2013 at 11:43 AM
