The engine was once opened by the mechanics but now it has no pressure and makes some noise when on operations.
Apr 2, 2018 at 10:36 PM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
No pressure as in what, no cylinder compression?
Why did a mechanic once open the engine and what did he do in there?
What type of noise does it make now and when, at idle revving up, in gear, hot/cold, etc.?
Apr 2, 2018 at 11:36 PM
DEE OJ
MEMBER
the mechanic changed the oil pump, the shaft, grind the valve, replace the cap change the the top gasket.
Apr 3, 2018 at 1:45 AM
PATENTED_REPAIR_PRO
Why did a mechanic once open the engine?
What type of noise does it make now and when, at idle reving up, in gear, hot/cold, etc?
Apr 3, 2018 at 2:08 AM
DEE OJ
MEMBER
The engine do smoke, like burning oil and when you drive it the movement is retarded. the mechanic open it because it once had oil water mixed and crank shaft sensor error.
Apr 3, 2018 at 2:24 AM
PATENTED_REPAIR_PRO
