Engine power reduced
135 MILES • 2.2L • AUTOMATIC
LEXIENICOLE12
So I’ve been having this problem for a while now and it’s starting to get really annoying. I’ve had people take a look at it and even went to get the codes read and fixed everything that the codes said and I’m still having this problem. It will once in a while drive perfectly fine and then I’ll turn my car off and it’ll go into “engine power reduce mode” I still drive it on it because it’s my only vehicle. Just the other day the car completely turn off on me in the middle of a parking lot! I let it set and started it up again and it was just into his engine power reduce mode and I had to put the peddle to the ground to get any speed. I’ve replaced the battery, alternator, pedal sensor, checked the filters. Even tried to replace the mass air flow sensor but the new sensor wasn’t working proper so I cleaned my old one and put it back in. I’m so frustrated with it. Can someone help? Also, my engine light is on as well. Thanks.
Jan 29, 2019 at 12:07 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Do you remember what the fault code is/was? If you don't have a scanner/code reader your local auto parts stores have a tool loaner program and can rent you one. Here is a tutorial showing what is involved:
Once you have that done and get back to us with the code information we can properly diagnose your car. Hope this helps and thanks for using 2CarPros.
Danny-
Jan 29, 2019 at 1:26 PM
LEXIENICOLE12
The last time I had it scanned which was about a couple weeks ago maybe, it read for the pedal sensor, and then nothing else was popping up, and which I changed the pedal sensor and am still having the problems. Everything I have changed on the car I was told to do to resolve this situation but it has done nothing.
Jan 30, 2019 at 6:57 AM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, I'll be glad to help but I will need the code number to help properly diagnose.Thanks again for using 2CarPros.
Danny-
Jan 30, 2019 at 3:27 PM
LEXIENICOLE12
I will get it scanned as soon as I can and get back to you, thanks.
Jan 31, 2019 at 10:10 AM
DANNY L
  • 5,648 POSTS
Hello again.
That would be great. Look forward to hearing from you soon so we can get this fixed.Thanks again for using 2CarPros.
Danny-
Jan 31, 2019 at 2:40 PM
