Engine power reduced
74,929 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
AGEL
  • 40 POSTS
Engine lost power and can't accelerate more than 40 miles. i have the check engine light on codes:
P0091
P0113
P0355
P2228
May 28, 2019 at 8:25 AM
  • 55,691 POSTS
Lets solve the first code and the rest should go away, if not you may have a bad PCM. The first code is code the fuel pressure sensor, lets replace it and clear the codes here is the location #7.
Part#
Sensor 12618108 $107.51
How to clear codes video:
https://youtu.be/ahK_eucFi-k
May 30, 2019 at 5:47 AM
AGEL
  • 40 POSTS
Good evening could you tell me what is the spark plug gap for it?
Jun 1, 2019 at 10:24 AM
  • 55,691 POSTS
Did you replace the fuel rail sensor?
Spark plug gap 1.1 mm (0.043 in).
This guide will help you install them:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Jun 4, 2019 at 3:09 AM
